fan controller voltage 7 v _12v
how do i increace the voltage to make the fan go fasterHuh?
link for fan http://www.ebuyer.com/customer/products/index.html?rb=18500434728&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=91657
Hey RT it seems as if eBuyer have got confused, this device doesnt display 4 different colours only blue.
The reason I have come to this conclusion is neither of these reviews mention it:
http://www.madshrimps.be/?action=getarticle&articID=141
http://tomshardware.co.uk/2004/01/30/case_master/
Sorry about that.
ultracool 11fan
how do you increace the voltage for the fan to run faster
MysteryFCM
fan controller
thanks all for your help i have looked for the manafatures web side cannot find one please help
Surely the idea is that the controller increases the speed as temperature increases?
If thats the case, then so long as the temp probes are in the right place, then the speed should be right?
Some fans will not work, they have to be 3pin fans with the yellow cable (sensor cable) attached.
And even fans that are 3pin can still not always be compatiable. Some cant have their fan speed changed manually because an automatic speed system is built into the fan and that can not be overriden.
