error messages in winxp
slanjavah
Hi can anyone help. Have just upgraded op system to xp pro with sp1. However keep getting message that program not responding. These are CTEAXSPL . exe & ccApp.
does anyone know what these do and how I can fix this?
Alecto
The first one doesn't do anything useful according to this and the second one is part of Norton Internet Security see here.
Both it seems can be safely removed or prevented from starting (Start.........Run.............Msconfig....select Startup and untick them.)
For more info do a Google on each or them.
I'd also download and run ccleaner which is free. It will clear up any loose files and bits lying around and if your run the Issues thing, will clear up any pointers and registry entries that don't make sense. One or other of these might be giving you trouble.
slanjavah
Thanks for reply will follow instructions and hopefully that will cure my problem havee cccleaner installed and have not run since i updated op system will do so now. Thanks again
may the force be with you
You should upgrade to SP2 ASAP as the security is a lot better with SP2
