error message with outlook express
Pamjmorris
Hi
All of a sudden i,m getting the message when i dissconect with outlook which reads
The instruction at 0x77F83907 referenced memory at 0x009A479C. The memory could not be written click ok to terminate the programe , i have been using this programe for year and this has just come up any suggestions please Pam
It is a memory error which suggest its either a faulty memory module or that the programe is corrupt. If its only happening in outlook then it will be the outlook thats at fault.
pcorker
Perhaps, with so many internmittent and varied faults, you should try running an intensive repetitive task for a long time to check for hardware faults (a crash). If it's OK then you could go back to configuration issues - if not then perhaps a visit to the computer shop?
I'll suggest repetitivly running a playlist of stuff in windows media player with a fancy visualisation going for about 4 hours.
This sort of task is called a "soak test"
Pat.
