dvd players
dvd players
elo, I was wondering if any of you know any decent free dvd players around for the pc. I have the basic InterVideo WinDVD but when I try and play the DVD's they are all jumpy and not much use. I've tried the powerdvd which is great and runs like a gem but you only have 30 mins of usage before you have to buy Sad any suggestions? thanks Wink
dvd players
The best DVD/AVI free player I use has to be Videolan
Ok it Looks basic but does everything I want it to do without needing any custom codec's
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
dvd players
Thanks, I've got it installed now but got no idea how to work it :?
I just wanna play my dvd Cry
dvd players
rollins1234 is right, it doesn't seem to do anything.
dvd players
Free players will normaly only work, if your have a DVD decoder and/or a GFX card that has a onboard decoder.
Otherwise, you need a Codec full stop.
Windows Media player will not even play DVD's without a codec, which it borrows from other players installed on your system, like Win DVD
dvd players
Is there a codec bundle or something I can get then?
dvd players
buy intervideos WinDVD 6 (platinum) its the best one out there and it snot that much (or hey download it ;P) and videolan rules. :p
dvd players
cheers Wink I'll have a look around, thanks all!
dvd players
i use Nero 6 Ultra with Nero Media player and Nero Showtime, also i use AceMega Codec's pro pack for XP, with these there is not format which i cant play. not that i would ever condone copying software, Cheesy but i use peer2peer software to locate codecs, and anything else i may need. do not use Kazaa, you will only regret it later.
