dazzle dv90 problems
I have just purchased a dazzle dv90 so as I can transfre my video collection to DVD via my pc. I have set everything up via the usb port. But I cannot seem to get the image to actually apprear when the software runs and you go to capture the vide footage. I seem to think I saw somewhere you may have to download some software updates but cannot seem to find anything about this on the Pinnancle web site.
Has anyone experienced simialr problems or runs the dv90 with no problems
Thanks in advance
Gary
mossgrove
You don't say what camera you are using. My experience is that USB only works for images from the memory card, and you have to use a firewire connection to transfer DV data. Check your camera manual carefully - they are often a bit vague in their wording.
Hi
actually I am trying to transfer across my VHS tape collection across using the Dazzle but am having problems in getting it to actually pick up the image from the tape as it plays in the vcr
Gary
