connection cut off
smokeyone
connection cut off
Has anyone any clever ideas to improve the connection to Plusnet. I seem to be disconnected every so often after about a minutes or so. It was suggested to try new tele line splitters or avoid the splitter alltogether which would prove very difficult.
Another ISP I use is a 100 times worse than Plusnet for cutting off so I am wondering if it really is my end or is this something I just have to live with.
Thanks in advance
connection cut off
Have you checked everthing on your wiring using the Wiring and Filters tutorial ?
Here
smokeyone
ISP connection
Thanks John for the reply. I checked your link and unless I have my wires crossed - mine is not a broadband connection. I had one thought though, the line goes through a discount tele call white box - will that upset connections.
Starclipper
Rich
connection cut off
Have you tried connecting direct to BT's master box - remove the front plate and plug the modem cable into the socket that will be revealed.
If this helps, then there may be a problem with your extension wiring or with the 'discount tele call white box'.
Also, what type of modem are you using? I used to use a cheap internal modem and had this type of problem. Changed to a decent external serial port modem and the connection reliabilty improved no end Smiley
smokeyone
connection
I am using a Rockwell Plus, PC156 V90 modem. The internal modem came with the PC. Anyway I will give the direct connection to the BT box a try. As I also mentioned before, even though I still have the disconnection problem, the Plusnet rate is 100 times better than a certain other ISP.
Connection
Hi
I am having the same problem with the 0808 dialup. I was advised it could be a modem problem, so I installed a new unit, but still have the same problem at "peak times " of the day. Shockedops: Shocked
pcorker
connection cut off
Over several years I found that the following made my dialup system much less likely to drop the connection:
1. Dropping soon after connecting: Insert a modem control string to force it to connect initially at a lower maximum speed. I use:
In IE's Internet Options/Connections/Settings.../Properties/Configure.../Connection/Advanced.../
+MS=V90,1,300,33600,300,44000 (Type the +)
Works for my el_cheapo V90 Rockwell chip modem. I think it stops it connecting at an unrealisticaly high speed from which it can't recover from fast enough.
2. Dropping generally: On the same page I move the Receive Buffer slider in "Port Settings..." to the penultimate (low) left "click"
This all seems to give better reliability at a slightly lowered speed.
And an MTU of 576 with a Small Packet Size (Heh heh!) in Adapter Properties
Pat.
connection cut off
Hey thanks for the info. Plusnet has been OK for the last couple of days, have not had the problem. I will make a note of the info, and if the problem returns I will give it a try. Shocked
