configuring redhat to work with my router
dontfollowme
I have just today installed Redhat 9 with all the default settings. I added my intel NIC which it autodetected without any trouble. I can't seem to work out how to connect to the internet. My router is made by etec and during bootup linux reports OK when bring up interface eth0. Any ideas?
By default redhat linux expects its IP address to be assigned using a DHCP server.
You have one of two choices.
1: If your router provides a DHCP server, enable it.
From redhat, you can then disable and re-enable the network interface (or simpler, type "service network restart" in a root console).
2: Specify the values directly.
This can usualy be assigned in the files located under "/etc/sysconfig/net*"
dontfollowme
Thanks for the reply. I just got it sorted by specifying the values directly which I did before but used the wrong values. I just have to adapt to doing things in a non ms now like installing software :S
