.con file how to delete it, download from the net by mistake
downloaded a file from winmx, which i thought was something else, and ended up with a file on my pc which has a realy long file name, and starts with .con , you cannot delete it and/or rename it.
gives error file is invalid or name is too long.
help
help
bump
Sheeesh... allow more than five minutes between bumping your topic! Smiley
Thomas
just in a hurry thats all,
and im used to a forum like this> http://www.saxosportsclub.co.uk/forum
so you have to on there, as there is so may post
Have you disconnected Winmx and re-booted your computer?
I gather its an Unknown file type. There are specialist programmes
such as ashampoo winoptimizer which have file wipers that can
bypass any built in protection but can't gaurantee it will work.
thanks, im gona download that and try,
but i read else where that you cannot delete a .con file in the win32 inviroment, is that true?
