brother dcp-34ocw all in one
hello all
sorry its me again with a problem i hope someone can help me with
got the above printer al inone from brother.
it says its wireless and to date can only get it to work wired.
i have a bt home hub thing 9wireless) and a hawking arial to get the signal from hub to pc and pc to hub
how do i get the printer to go wireless.I have had ago but it cannot find any wireless in the area
not my pc nore the hub
any help will be greatfully recived
1 REPLY
I looked at the spec and it doesnt show it as having wireless on the printer. A lot have them as a added extra so it may well have it. You need to find out how to setup the printers wireless it may be disabled for a start. Normally its the control panel on the printer but it could be on the network card if its an addon.
the manual and help for the printer is here
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_top.html?reg=eu&c=gb&lang=en&pro...
Next you will need to set the ip address of the printer to the same range as your network so if your network is 10.0.0.1 then the printer would be 10.0.0.2-10.0.200 just find the ip of the last pc and add one and make sure the subnet is the same range if you do a ipconfig /all on the pc it will give you the subnet.
Having done that you should be able to see it on the network
