bluetooth keyboard in bios
has anybody managed to get a working bluetooth keyboard in the bios of motherboard asus a78x-x or any other motherboard in this case
i have a bluetooth microsoft optical desktop elite
any suggestions appreciated
cheers
holdtight
Have you tried enabling "legacy usb support" within the bios ?
this is often the cause of devices such as this not responding if its set to disabled which most boards are by default
yh i have enabled legacy support usb
but i have to admit in normal mode in windows , the keyboard won't work straight away
by that i mean i will have to tap a few buttons , there is a 5 second delay then it will work perfectly fine
(i've added you to msn if thats ok with you)
cheers
