blocking computer internet access
i gt a netgear dg834
with 2 computers connected to it
i want to block one of the computers internet access
how do i do that?
my one is the mainn computer
want to block the other computer from using intrrnet
is it possible to do that but still be possible for that computer to communicate with my computerHuh?Huh
Are there any firewall rules wtihin the setup? you could try to block all incoming / outgoing TCP packets to the second PC's IP address. This would kill the net. You could also just add a 2nd NIC to your main box, and have a cable linking the two boxes together that way. Or install a software firewall on the 2nd computer, and set it to deny all traffic destined to the outside world.
Buz
As Buz has previously stated, you can block all out going and incoming access using the firewall within the router. However you may need to add addition rules to allow basic networking between the machines.
you could do it by subnet
allow all 192.0.0.X between the boxes but disalow it from the subnets of the PN ip rang you have
thx 4 ur help ill try out your solutions
madswitcher
Hi All,
I use a Draytek 2900 router and some beta firmware has just been released to block P2P traffic.
So far it cannot be time sequenced but includes:-
- eDonkey (eDonkey, eMule, Shareaza, MLDonkey)
- FastTrack (KazaA, iMesh, MLDonkey)
- Gnutella (BearShare, Gnucleus, Limewire, Phex, Swapper, XoloX,
Shareaza, MLDonkey)
- BitTorrent
Might be worth looking at
Regards, Mike
