best gaming case around
i need i case that will keep my 8800 gtx cool and my raptors
best case around i have a nzxt zero
look at my last post
GersFans
Have a look at the antec P180, an excellent case for gamers/overclockers.
holdtight
Not exactly a gaming case but for the last five months or so ive been using the Jeantech apollo which ive found to be excellent for keeping everything inside quite cool
The only problem i found with this case is the so called manual (a scrap of paper) that tells you nothing about the internal wiring but with a little time it all comes together other than that im very pleased with it
It will take all your drives and more as its quite large and a plus for me is its also on wheels so easy to shift about
