belkin router udp flood
Any one know of a workaround (other than disabling firewall) for a belkin f5d7630-4a wireless router. The issue being VOIP traffic causing * * UDP Flood to Host * * in the security logs and then disconnects, router refusing connection, loss of sound.
google so far has not been my friend with this one Wink
At my wits end after days of random failures on VOIP, to then discover the UDP in the router security log, re-booting router, waiting a long while solves it. Turning off firewall solves the issue and sound quality also improves. Though I REALLY want to use the firewall in the router as a first line of defence.
Mark
