belkin moden.router
belkin moden.router
Hello all
I want to upgrade my moden.router its a belkin and the new one is same make but is faster .
would you say i would have to uninstall the old stuff moden.router and wireless adapter or do you think i can just add the new one's.
Any advice would be welcome
belkin moden.router
Hi
Your posting is a little confusing, are you using a modem or a router (with a built in modem).
If your using a router unless it's USB (normally they are ethernet) then no changes are needed. Ethernet modems or routers don't require any additional software on the PC
belkin moden.router
Thank you
seems to be working ok now
had a few probs but fingers crossed it keeps goin
thanks again for your advice
any one know anything about email virus ?Huh
Denzil
belkin moden.router
Can you be more specific? That's a very open question!
