[b]SOLVED[/b]cannot surf website-due to firmware prob
i now have this problem...it seem i cannot surf into other pages.
e.g when i do the ping..->time out
common url:
www.ebay.co.uk
www.tiscali.co.uk
the only setting i have change in router is setting up Virtual server
port 50100-50119
i assume there is no problem even i disable it,i still cannot surf the page.
i also clear cache and temp files.
had been ask other people use same ISP with no prob?
is that possible the cache setting?or any suggestion?
If you are getting ping timeouts, then these are network problems, however, which part of the network, you will have to determine.
Instead of doing "ping address", use "tracert address".
Then paste back the results.
It should show you where in the path the ping fails.
following up acarr solutions
thanks/////that a gd idea...forgot abt the command.
here is the result for ebay.co.uk
Microsoft(R) Windows 98
(C)Copyright Microsoft Corp 1981-1999.
C:\WIN98CHI>tracert www.ebay.co.uk
Tracing route to www.ebay.co.uk [66.135.192.41]
over a maximum of 30 hops:
1 * * * Request timed out.
2 12 ms 17 ms 16 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 13 ms 15 ms 15 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 19 ms 16 ms 14 ms 212.113.11.33
5 18 ms 16 ms 13 ms 212.113.3.29
6 17 ms 21 ms 16 ms 212.113.3.9
7 30 ms 28 ms 30 ms 212.187.128.46
8 102 ms 104 ms 105 ms 212.187.128.138
9 170 ms 171 ms 172 ms unknown.Level3.net [209.247.9.114]
10 173 ms 174 ms 170 ms ge-6-2.ipcolo2.SanJose1.Level3.net [64.159.2.132]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
till 30 hops.
and this is tiscali.co.uk
C:\WIN98CHI>tracert www.tiscali.co.uk
Tracing route to www.tiscali.co.uk [212.74.101.10]
2 14 ms 15 ms 13 ms lo0.plusnet.pth-ag1.plus.net [195.166.128.11]
3 17 ms 15 ms 15 ms gi1-2.vlan3.pth-gw3.plus.net [212.159.1.2]
4 14 ms 13 ms 16 ms lon1-10.nildram.net [213.208.106.89]
5 24 ms 21 ms 26 ms linx.lon20.ip.tiscali.net [195.66.226.32]
6 tiscali-uk-1.ip.tiscali.net [213.200.77.130] reports: Destination net unr
achable.
Trace complete.
thank you Acarr for the help that i am getting Cheesy
my router setting
the setting of router is 10.0.0.2
with in the range of 10.0.0.3 to 10.0.0.14
my ip is 10.0.0.12
also i am the only connection connect at this time.
if i turn on the other computer with in its ip range still cannot view other website.
The frist trace stops in a Level3 router. Level 3 block most of there ICMP, so this of little use.
The second trace shows the destination is unreachable, however, the last trace being a Tsicali router. This means it is a Tiscali problem.
The frist trace stops in a Level3 router. Level 3 block most of there ICMP, so this of little use. ----by acarr
as i can see that in both case that 1 hop is requested time out.
is that what you mean by level is 3 block.
if so can you specifly more and tell me how can i undo the block or what can caused the problem.
thank you
This is your first trace.
Each hop in the list is a router or machine that the traffic has to pass through. This can help you determine the route that your data takes, and locate where in the flow of your data it has problems.
Hop 1 is your router.
Hop 2 and 3 are PlusNet systems
The rest are Level 3 systems.
As the failure takes place in the Level 3 network, that means that the issue is in there network.
Tracert uses ICMP packets. Level 3 are known to block these within there network. As such, there is nothing you can do to stop this.
WIth the second trace, the destination is unreachable. This means Tiscalis system are quite simply but, dead.
thanks for ur sugestion .
as i understood all the thing u had said.
but i can able to connect via 56k?with no problem.
also
johnessex
Forum Moderator
Posted: 04 Apr 2004 08:43 am Post subject:
I can connect to both of the above with no problems.
can able to connected with no problem.
can you connect the site?--acarr
www.screaming.net
www.ebay.co.uk
i know what is it...i solve the problem.....
cause by the firmware of the router itself
WOW Cool
:twisted: :twisted: :twisted:
