ati x800gt help
ati x800gt help
games will freeze on start up and blus screen please help
arock duel satta2 m/b
win xp
1 gb ram
satta2 160 gb hdd
Fixes: 57
ati x800gt help
which games, processor and motherboard - there are a whole range of Asrock Sata2 boards
To add to the comments on the following post - has this PC worked with another graphics card or is this a new build.
Is everything running at stock settings
Does the bios have a performance setting and are you using it
If this is a new build have you checked the other components - memtest is an obvious one.
Does your X800GT need a supplementary power feed - I don't think it does as it only draws about 70/80 watts from the PCI-E bus
ati x800gt help
what psu do you have? (probably not enough juice going to the card)
edit ::
edit to ask other important things you should have given us:
What wattage / peak / normal is your PSU
what cooling does the card have?
what cooling does your case have?
what drivers are you using for the card?
what error is given on the BSOD?
why are you so bad at giving us information that is critical for us to know?
