aol 9.0
aol 9.0
does anyone no if aol will interfer with my wan. i have two machines connected and it works sweet. my third machine is having trouble resolving the ip. the only difference is its running aol. help? :lol:
aol 9.0
AOL should make no differnce I have done several networks with AOL9 and it all works fine. What it does do is try to make AOL dial up the default connection. If it does then windows gets confused.
Check in IE to see what your default connection is. Have you set AOL up so it knows its on a network which isnt AOL?
aol 9.0
thanks ill give it a shot
