any1 know a good free pop-up-blocker
any1 no any good 1s as fed up with the things now.Hopefully one you can turn off when you want.
The google toolbar has a good blocker built in.
Any popups it doesn't stop are generated by somthing on your own system. So it is handy to have that as a wanring sign.
michaelscott
the mozilla and mozilla firebird browsers come with built-in pop up blockers.
thanks acarr+michallscott i,ll go have a look at them both[CHEERS].
go to www.panicware.com and dl the free pop up stopper i have been using it for about 1 1/2 yers its gr8 Wink
take it yir scottish mate ,cheers am away 2 look.
googlebar is brilliant.
the search tool is handy is aswell.
wot made yah think that Wink
As suggested if you install the (free) google tool bar you will get the option to activate a 'pop up' blocker. It works fine!
cheers every1 ,went with the google bar and it works great.
