an Easy One
an Easy One
Hi
My sister has Win XP Home Edition........ what does she need to type at "Start/Run" to find her IP address for the current internet connection? I thought it was "ipconfig" as I am sure that is what I used when I had Win 98SE,but tried that on my wifes laptop (also Win XP) but it does'nt seem to work.Or is there an easier way for her to find it.
IanJ
painswck
an Easy One
Hi Ian,
The command still is ipconfig but with XP type it at a command prompt and not at start/run. From start/run the prompt box does not stay open so you may not see it at all..
Hope this helps
Roland
an Easy One
type cmd in run to get the command prompt ie dos window, then type ipconfig in that window
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
an Easy One
type it at as command prompt .quote]
Thanks Roland I did see the box open and close for a fraction of a second :-).But never having used Win XP may I impose on you a little more and ask where in XP one enters a command prompt?
Thanks for your patience
IanJ
an Easy One
thanks adp450
Roland please ignore my last posting it's all sorted
Thanks folks
IanJ
