Your opinions on mb
Your opinions on mb
Right either today or 2moro i think i will be ordering a new processor and mb. I know what processor to get, the amd 64 939 pin winchester. But i am thinking to much about board make. I have asus which was working ok but when i mates togther he had a faulty asus board. I hear msi are good, but not sure. Any ideas
Also should i invest in a new psu. Somthing which aint so loud. Current psu is 450watt but its a cheap one.
Links would be good to thanks all
Your opinions on mb
Im guessing that u use a AGP card and will be keeping it so i would recommend the MSI Neo 2 Platinum. Ive been using this board for about 3 months and it rocks, lots of features including - nforce 3 chipset, dual lan, dual channel memory slots, 7.1 audio, s-ata and plenty more.
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=607
If your planning to get a new psu i would say dont ever buy a cheap one, good quality psu's give much better overall system stability. About the £50 mark would get you a mint psu
Try these http://www.overclockers.co.uk/acatalog/Hiper.html The third one down is pretty good
Your opinions on mb
I think i will have to get a new psu another time i was hopeing not to spend over 200. Well i will be keeping my graphics card. The ram 1.5gig crucial. My 2 hard drives both ide. And my case. Nice board how much is that one
Your opinions on mb
The board i think you can get for a low as £80.
Check here http://www.planetprices.co.uk/hardware/32/2100790/1/MSI-K8N-NEO2-Platinum.html#
Even if you dont have sata hard drives yet you may wanna stick one in sometime in the future, so it would be a nice addition to your sys.
Hope that helps bud
Your opinions on mb
Yeah thanks for the links dude. Just saved me some cash. I will get them orded 2moro. Is there much profromance difference in the amd 64 3000 and the 3200. I hear there not much different
LiamM
Your opinions on mb
I use MSI a lot and have always found them to provide robust, stable and reliable boards.
It's for this reason I always look for MSI when I am system building etc... You can't get much better!
Your opinions on mb
Yeah msi look the daddy so i think its gonna be them. Thanks for the advice and i will let you guys know how it goes
Your opinions on mb
Right orded the board and the amd 64 939 3200 wincester. Good job my pc had just died. Hopefully there here soon
