Xbox
Xbox
hi all, does anyone know of any problems setting an xbox with an ADSL/Router? :shock:
Xbox
I dont no any problems but i use the easier option as in the ics sharing as i know how 2 fix it if owt goes wrong. But ask around about the router
Xbox
thanks for that, was mainly conerned about ports and stuff like that, cause i understand the router will have a built in firewall?hasnt been delivered yet, but no harm in being prepared!
hopefully it will be a simple case of plug in and away i go Cheesy
Xbox
You could download your router manual and have a look
in advance.
You'll need to open ports UDP 88, UDP 3074 & TCP 3074.
This will usually be covered under port forwarding, firewall rules
or NAT rules.
If your router supports UPnP and you have it enabled then
the router and X- box can communicate automatically.
Either way it should be pretty straight forward.
Alec
Xbox
thats gr8 thanks for the info, its being delivered today according to Citi Link, but im in work doh! couldnt someone have phoned me first lol Cry
