XP Network Diagnostic
I have run a diagnostic test and the results show a fail for both email and news. My email seems to run slowly and is jerky eg downloads several quickly then pauses. Do I have a problem and if so how do I fix it. The report is reproduced below. I am using a netgear 834PN wireless router synced at 2.8mbs but speedtests show only getting 1.3mbs
Default Outlook Express Mail mail.storth.com / localhost FAILED
InBoundMailPort = 110
- InBoundMailServer = mail.storth.com (FAILED)
Pinging mail.storth.com [213.171.216.65] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 213.171.216.65:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
InBoundMailType = POP3
Successfully connected to mail.storth.com port 110
OutBoundMailPort = 7362
- OutBoundMailServer = localhost (PASSED)
Pinging RobsPC [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=0
Ping statistics for 127.0.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
OutBoundMailType = SMTP
Successfully connected to localhost port 7362
- Default Outlook Express News news.plus.net FAILED
NewsNNTPPort = 119
- NewsServer = news.plus.net (FAILED)
Pinging nntp-readers.plus.net [84.92.1.10] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 84.92.1.10:
Successfully connected to news.plus.net port 119
Is mail.storth.com hosted on Plus net? Most mail servers wont let you send mail unless it comes from their IP range so if its not on Plus net that maybe the problem
What anti virus are you using? It seems you are going via local host so it suggest you try to pick up your email from a local server like ones with AV and this then passes it on to the real server.
Try setting your mail to the ip address of the servers and see how it goes but beware your mail may not be scanned for AV.
Slow email
No storth.com is hosted by streamline.net. I use Nod32 anti virus and Zonealarm firewall.
