Wireless question
Wireless question
Can you contect two pc with two PCI wireless cards? Will they talk to each other?
Simple quesion I hope.
I was hoping to buy just two wireless pci cards to allow a second pc to use my internet. I am looking for the cheap option and wired is not possible
Thanks kind people
Malc
Wireless question
In simple terms yes if you set the network cards as adhoc mode you can connect the pc's
Wireless question
Thanks, I have ordered them
