Wireless 802.11g modem router
Which is the best one to buy and which ones should I avoid?
Someone, or perhaps many of you, will tell me to use "search". I did and found nothing.
Thanks in advance.
Well using Wireless AND router as the search criteria has just returned me 8 pages of posts :?
My explanation was not very accurate. What I should have said is - YES it gave me many pages of posts but NO it did not answer my question.
Hope this helps - I am not entirely senile just yet.
how much do you have to spend?
I use a DLink DSL-G604T all in one. Supports WPA as well. Great bit of kit. Very easy to set-up.
linksys make a very nice one (how many of you didnt see me making this post :p)
It would help if you stated a model number... I assume you mean the Linksys WAG54G.
And the similar Netgear product is the DG834G.
yes i did mean that one Smiley thanks
(sorry for not posting the number.. i was in a hurry)
I was asked how much I want to spend. The answer is as little as is necessary. I have no idea how much is "necessary" without having somem idea what is necessary.
ok then.. what do you want to be able to do / intend to do with you line
download stuff
host stuff
run a website
run a mail server
etc etc etc
buz
download stuff is all at the moment.
then you will be wanting a cheepish one that does some basic firewall rules to protect your ass from hackers while downloading
