Windows media player 9?
Hi guys i have a fault with my windows media player. When i watch a dvd via media player 9. 5 mins into the movie the sounds goes off and i dont no why?
Any help plz
Does the sound go off totaly? As in, no longer existant?
How do you restore it?
You could try just reinstalling WMP9. Or, try installing an alternative application and see if that does the same. Does it matter which DVD you watch or do they all exhibit the same behaviour of no sound after 5 min?
Yeah they all do it its werid. I have 2 load up the dvd again 2 make it cum back on but then it goes off again
is it every 5 minutes exactly?
i had the same problem and i couldn't figure out why - i had entered my licence information in for the decoder (windvd).
try uninstalling then reinstalling the decoder.
Windows Media Player does not require a licence as it is part of Windows.
Read all of what I said. Windows Media Player requires a decoder - which is not provided by Microsoft. You have to purchase a third party decoder.
Moderators note (John) Full quote of previous text removed at its not needed
Cyberlink's PowerDVD also hooks into Windows Media Player.
The trial version of PowerDVD does exactly what is described. Plays a certain amount of the audio then mutes, but carries on playing the video
Yup - I eventually just bought the add on decoder for powerdvd. Works very well with Windows Media Player. - Good for on the plane!
Windows Media Player.......... Bahh
the best advice i can give u about windows media player is .. UNINSTALL, its crap to be totally technical try using power dvd or divx player if ur a cheap scate, or go for Nero 6 Ultra player or Ace Mega Pro Codecs pack version 5.1 if ur in the know they r top
