Windows XP Pro
Windows XP Pro
want to upgrade to Windows XP Pro from Windows XP Home - Do I have to uninstall Windows XP Home first :?
Windows XP Pro
Just put the cd in and it shud say install or upgrade os sumert like that
Windows XP Pro
This depends. If you have Home Edition with SP2 installed and you put a Pro CD in your machine which doesn't have SP2 included, you cannot upgrade. You would have to remove SP2 first.
