Windows 64Bit Edition
Been thinking about getting this os as i have a 64 bit ready comp.
Is anyone else using this edition? can they give me some feedback please?
Would hate to install only to find it has some major probs.
afaik xp64 is still in beta tho i hear its pretty stable. you may have some problems with hardware drivers.
Yeah i was thinking of geting it as now i have amd 64 now.
I'm going to wait until the final release.
MS have promised to swap 32 bit versions for 64 bit versions FOC as long as they aren't OEM copies.
been using windows xp 64bit for about 6 months now.. so far its stable for the beta version..
I was going to but there's no support for my sound card and the missus uses my PC's TV card when she works from home to keep her company and that doesn't work either under x64.
I did try the beta, however wasn't keen on the fact that each time they got a new one out the update facility stopped working. Oh and my other concern was that Norton wouldn't work on it - haven't tried the corporate edition yet that I recently moved to.
Thanks for your comments guys Cool
Well ive dowloaded my own copy and its sitting there ready to go Smiley
May just itch my head one more time and think about installing tomorrow....
Do you get this from windows.com then
yep i got it from microsoft weby Cool
http://www.microsoft.com/windowsxp/64bit/default.mspx
You get a 550mb download and a cd key via email valid for 12 months only i think Shocked
well it will be out sooner than that i think
thanks for the link man.
Also will it remove all the saves i have on now
ie my vids and images etc
If you only have one hard drive m8 then yes you will lose everything so back up all your personal files onto cd/dvd before installing windows 64
Yeah thought so. Thanks for the advice again
