Window's media player
tonka
can anyone tell me if it's possible to add your own radio station's in to window's media player 10 and how to do it .cheer's in advance.
I had this problem before... My local radio station uses WMP to broadcast over the net.
I got it running in Windows Media Player, and then went to the properties, and grabbed the Location.
Then go to File > Add To Library > Add URL...
Put the Location in there, and then it is added to your library.
Craig
tonka
how did you get it running on window's media player first though,cheer's in advance.
[Moderator's note by Liam Martin (martinfamily): Full quote of the preceeding post removed as it is not needed.]
What radio station is it?
I'll have a look and see how to do it for you.
Craig
tonka
its 105.4 century fm ,cheer's mate.
[Moderator's note by Liam Martin (martinfamily): Full quote of preceeding post removed as it was not needed.]
What you need to do is this.
Go to File > Open URL...
Enter http://ms2.capitalinteractive.co.uk/century_1054
This will then connect to the file and buffer it.
Then, go to your library and then Other media to check if it has been added.
If not, go to File > Add to Library > Add currently playing item
That should get it into your library!
Craig
tonka
cheer's thank's very much for that great help.is it the same to add more radio station's like radio 5 606.
Yes.
As long as you can find out the address of the stream, then its the same process.
Craig
tonka
found the address of the stream but it's asking for codec's is that because they play them on real player.
Yeah, you'd ideally have to play it in Realplayer if thats the only stream they use.
Mine actually uses Real and Windows Media, so i prefer to stay with Windows Media
Craig
