Widescreen arrives on my Computer
Got a third graphics card and monitor fitted and working Cheesy
Makes gameplaying a bit easier because i can have map, macro and stats windows on other screens and i can also read forums while playiing
http://www.alienonline.plus.com/c9bc4710.jpg
[Moderator's note (by csogilvie): Image removed as it was stretching the forums.]
csogilvie
Nice to see another DigiGuide user Wink
Do you have yours customized as well?
I'm using a combination of colours and sounds to make it easier to spot my favourites and its worked well for the last year+
Not content with fitting a 3rd graphics card, i've now got a second sound card installed and working now Cool
Even found a PCI to USB card which installed without any problems, it gives me a extra 2 USB slots to fill up.
