Which ethernet controller should I use?
fotobits
My computer is connected to a LAN in order to share a broadband connection with another computer.
My computer has two ethernet controllers, an NVIDIA nForce networking controller and a Marvell Yukon 88E8001 PCI 32bit gigabit ethernet controller.
Which controller should I use? Is one controller better than the other, or does it make no difference?
They seem to perform similarly.
Regards and thanks for help.......
Noel
As your broadband is 8 meg max and the net cards do up to 100 meg it will not make much differance which you use
fotobits
Many thanks, mwright, for your info and fast response!
Regards.....Noel
