Where in XP?
Where in XP?
Where in WinXP would I find the equivalent of Win95, 98, Me, 2000 etc "Start-up" folder that controls which programmes and applications open at boot-up?
Where in XP?
Hi
On my wifes computer I use start/run and then type in "msconfig" which seems to work ok for her machine.
Hope that helps
IanJ
Where in XP?
Thanks IanJ, Excellent...
PL
Where in XP?
If you want one that works a lot better then go type in autoruns in google and then download a tool by the same name from pstools
Where in XP?
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
holdtight
Where in XP?
And dont forget services start a lot of things with XP that you dont need or
could do without, have a look
Here for a guide as to which you can disable and those you should keep
Control panel / Admin tools / services
