What's Firewire?
worcsdave
What's Firewire?
I'm thinkig of getting an iPod and see that you need a firewire connection with your pc. What is it?! And how do I know if I've got one!
Cheers
What's Firewire?
Firewire is also known as IEEE 1349. It is a connector type that may be available on the front and/or rear of your computer case, designed to deliver high speed connections to pereferals like the iPod or external Hard disk drives.
Take a look at THIS image. The bottom type images are what you need on your computer.
You have two further options however.
1: Purchase a seperate firewire PCI card for your system. £16 +P&P HERE
2: Purchase the seperate USB2 cable. This will work on a USB 1.1 machine, but at slower speed. I suggest using a USB2 port if you have one, or adopting option 1, possibly getting a USB2 card instead.
worcsdave
What's Firewire?
Thanks for info. I'll have a look and see what there is on my pc!
Cheers
What's Firewire?
Firewire cards are about £4-6 on ebay often with a cable. Local shops charge £20 for a card and £16 for a cable
