WebCam IP
WebCam IP
As PlusNet has a fixed IP address; was wondering who had hooked up a permanent WebCam to do home surveillance etc?. Ideal if could them access the Video Stream from a Browser URL IP Address when away from home. Any ideas/approaches?.
WebCam IP
Personally, I use an application called Active WebCam( http://www.pysoft.com ), works splendidly! You can set it up to detect motion and send you a snapshot to an email address. It's not video streaming, that I think is not allowed by PlusNet's T & Cs. I get something like 15 frames per second which is more than adequate.
WebCam IP
IIRC, the streaming part of the contract only refers to streaming through your webspace.
Although expesive, look at the Axis range of cameras.
