Wake on LAN
Wake on LAN
Does anyone know of any good WoL utilities.
I have been using a GUI client, downloaded from http://www.depicus.com/wake-on-lan/
The utility works fine over the LAN, but if I'm outside I can't get it to work.
I'm using a Vigor2600 Plus ADSL router, with a VPN server built in. If I VPN in, the WoL still won't work to the internal IP addresses.
Any advice?
Wake on LAN
I've solved the problem.
The routers don't usually directly support WoL packets - even over VPN. So I've upgraded to a beta firmware which has a wol command built in. You can telnet into it and issue a wol command directly from it.
arlehaven
Wake on LAN
Well done Davien,
It's nice to see someone solving a problem and then telling us how they did it.
Might help others in the future.
Cheers. Cheesy
