Wake on LAN
Wake on LAN
Hi, I'm another newbie to ADSL. I did a search on a few forums but couldn't see an answer so here goes....
I have recently come over from BTYahoo dialup. I have now added an Origo 8400 router and a Lynksys 10/100 card to my PC setup. I had no trouble setting it all up and have no problems with connection or speeds but have noticed that the computer now occasionally boots itself up at about 5.30am!! I assume this must be something to do with "wake on lan". I've noticed that the LAN light stays on on the router when I switch off the PC.
Where should I be looking to prevent this happening, in the router / lan card set up or the motherboard / bios?
I am running Windows ME with an Athlon XP2000 on a Gigabyte motherboard. AVG anti virus, Agnitum Outpost (had problems with ZA a few years ago so ditched it) Spybot and AdAware.
Wake on LAN
WOL (wake on lan) can have one of two possible triggers.
1: Magic packer
Specific data desatined for that specific machines, that tells it to boot up or come out of sleep mode
2: Activity sensor
Dectects activity and causes the system to boot (your cause most likely).
There is two further caused to this.
1: Computer has a timer in the BIOS that tells it to make at that time of day
2: A fault in the BIOS firmware.
All of these settings can usualy be changed from the BIOS, under power managment area.
wake on LAN
Just as follow up to this.
I firstly tried disabling WOL in the bios but after a couple of days the PC booted itself up again at 4AM.
The next step was go into the ethernet card properties where I found the "magic packets" mentioned in the reply to the original post. I disabled everything and now many weeks later I still have broadband and get a full nights sleep! Cheesy
