Voyager 205 Setup
Voyager 205 Setup
Just recommended Plusnet to a friend. He ordered the voyager 205 router, however I couldn't seem to open the configuration page (192.168.1.1), so I proceeded to setup the router on my laptop, which worked fine and connection established. However when I reconnect his computer error 403 occurs with, forbidden access, Access denied by access control list. Don;'t know much about networking, any simple way to fix this?
Voyager 205 Setup
It could be windows firewall stoping it or it could be it uses java/javascript and windows doesnt have it or you are missing the message at the top of IE asking if you want to allow it.
Is the network set to the right ip range on the pc?
Voyager 205 Setup
thanks for reply, I was suspecting firewall issue and will try to disable it, however the computer will connect when I use a usb modem. I'm sure the computer is within the IP range (being 192.168.1.4) is there any way of confirming the range, in case this is the problem?
