Viewing Source in IE
For somereason I can't view the source of a web page now in IE - anyone know how I can turn this back on..
I have gone into the options and can't see anything obvious.
TIA
First, make sure you have a "HTML Editor" set in Tools -> Options -> Applications
If you have, you may find clearing your cache helps this.
Yes, clear your cache. You'll also find a full cache can make IE tell you you have a corrupted zip file for some rather odd reason.
Thomas
Neat... or is it COOL... worked fine thanks.
Problem solved
