View Source in IE6
View Source in IE6
View Source in the VIEW menu in IE6 does not work anymore. On Win2K. What givesHuh?Huh
Ianwild
View Source in IE6
I had exactly this problem.
Try emptying your temporary Internet files - That fixed it for me.
View Source in IE6
Works a treat. Kool. How bizarre. Will check the MS knowledge base. Thanks.
View Source in IE6
yeah, same here, just emptied it and worked again Cheesy
View Source in IE6
Worked here for me as well! This has been really annoying me for ages!
Thomas
View Source in IE6
LMAO, thanks for the tip.
I am having to work on parts of my personal web-site (+Net related, you may like it) from work, all because I can't view the source.
It seems to work perfect for offline files, but anything from the cache is anoying.
I will try this now from home later. Oh well, back to slow sites for a week.
View Source in IE6
I usually have my temp net files set to a max of 50MB and have never experienced this personally Smiley
