Video Compression / reliability
All,
Have a quick question for you based upon a couple of problems i am having with a judging decision.
Basically someone has videoed an event where speed is critical - then they have ripped the video into a WMV format from their camcorder. My question is this: How reliable can the timing of this video be - e.g. can the Frames Per Second be relied upon?
I would appreciate if anyone knows an answer to this and if possible any way i can back this up or check the timings etc...??
Cheers - Chris
1 REPLY
No. Every electronic device is different.
There are two problems
1: Analogue capture rates are more inacurate than digital
2: Digital to analogue conversion makes things more inaccurate again.
I can't quote anything legal or referance matterial, however, one path to follow is that the software and/or hardware used did not have a speed calibration certificate.
