VPN & Netgear DG824M
I want to run a VPN client at home to my work place, The DG824M say (in the spec) it supports VPN pass thro', but I can't see where or how to make sure its turned on.
Any ideas what inbound/outbound ports I should open.
Does Plusnet suppot VPN pass thro's?
cheers
Fores
1 REPLY
You don't have to do anything to use VPN through the router. The 'pass thru' means it won't interfer with any VPN sessions that you establish through it.
PlusNet also don't block VPN on their network.
You just need to install and run your companies VPN client on your PC then connect to your network as they describe.
