VPN & DG834Gv2 problem
megadyptes
Folks,
I have a slight problem trying to connect to a server via VPN from a laptop.
The laptop is connected to a Netgear DG834Gv2 router using wireless with a reserved IP address and I've added a couple of firewall rules to allow VPN-IPSEC traffic between the laptop and the outside world, but the connection never seems to succeed when I run the Cisco VPN client software.
If I use a dial-up connection instead of the router then I can connect without a problem, so I'm kind of guessing that the problem resides with one of the router settings.
Any ideas on how I can go about trying to figure out what the problem is?
