VIASRAID Driver File Needed
NewtonGauss
I'm trying to create a bootable CD using Bart's PE Builder and everything seems fine except that it reports that viasraid.sys is
missing. Trying to add this driver, I can find the files viasraid.cat,
viasraid.inf, viasraid.pnf and viasraid.sys on my hard disk but not the
related txtsetup.oem file. Can anyone provide this file or point me in
the right direction?
Looking in the viasraid.inf file shows DriverVer=09/04/2003,
5.1.2600.210. My system is based on an AMD Athlon 64 3500+ CPU and an Asus A8V Deluxe motherboard.
Alex Balfour
Seems to be alot of people referring to this viasraid.sys error, there are many work arounds supposebly. Best bet is googling "viasraid.sys error" and hoping that one of the forums picked up on the search will offer a working work around.
Sorry I cant help further, I had a little look but there is so much there it would be difficult for me to pinpoint the exact problem.
NewtonGauss
I don't really have a problem. If I could get a hold of the correct txtsetup.oem file, I'm fairly confident that I could create my bootable rescue CD using Bart's PE Builder.
Alex Balfour
