Utorrent
Utorrent
Hi was wondering if anyone has any idea how to solve my little problem :twisted: While running utorrent on my system i cannot browse the internet at the same time it comes up as page cannot be displayed but as soon as i switch utorrent off everything is fine :?:
any ideas please :idea: :lol:
Utorrent
Sounds like utorrent is using the same listen port as your browser. Just go in and change utorrent to use a port1 numbered between 10000-65000, these are less likely to already be in use.
If this isn't the problem and I am talking a load of whack, try a re-install of utorrent.
Utorrent
thanks will try that
Utorrent
:lol: works great thanks :lol:
Utorrent
Hmm..my utorrent all of a sudden is saying all ports are closed no matter what. Was working fine a few days ago.
Utorrent
My utorrent is working fine better than ever today
Utorrent
Try a re-install of it and make sure your pointing to a port that is definately open. Or make sure UPnP is enabled.
Utorrent
Tried both - no luck, all ports still closed and upnp is on. How do i know what port is open e.g. ftp/html. But still, it was working fine before and now all of a sudden it isnt.
