Using router to route home WiFi network
lunchbug
Hi.
Can someone please help me get my head around how to do this ?
I appear to have a failed Solwise SAR705. My ADSL light just blinks, despite proving the ADSL line with a USB modem, resetting to factory defaults, reconfiguring via setup scripts obtained via this forum etc.
My home network is connected thus:
  • PC-1 connected to Internet via USB modem with dynamic IP address.
  • PC-1 Windows XP Internet Connection Sharing enabled on USB modem connection
  • PC-1 wired to SAR705 & running WiFi & connecting to home wireless net + DHCP enabled
  • SAR705 wired to hub & serving DHCP
  • Wireless Access Point wired to hub & providing home wireless net
  • PC-2 running WiFi & connecting to home wireless net + DHCP enabled
I want to be able to connect PC-2 via WiFi to use PC-1's Intenet connection.
Dave. :? :? :?
I think your easiest solution would be to get a 4 port ADSL router (cheap enough these days) and then you can just connect one PC directly to it via cat 5
cable and also connect your wireless access point to it.
Both PC can then use the internet independant of each other.
So Router ---> PC1 and wireless access point.
PC2 To router via wireless.
Or both PCs to router via wireless if you have cards in them both.
shermans
John's solution seems the only sensible way to do it - internet sharing, I thought, was only ever intended to be a stop-gap measure. I use what John is suggesting, using an XP desktop and a W98 laptop and I have never had any problems. Very easy to set up and fast networking also. In this weather, I have been working wirelessly under a tree in the garden !
Mind you, I do not know what is actually to stop two neighbours sharing a single broadband connection this way and thereby halving the cost - for that matter, what about a community connection ? The problem might be acceptable usage volumes, but for the casual user, which probably most people are, that would not be so much of a problem !
lunchbug
Thanks both. I had the setup John described, until the ADSL modem router (SAR-705) stopped talking to the ADSL.
I'm now trying to use my USB modem together with the still working router part of the SAR-705 and my existing WAP to allow me wireless Internet once more.
