Using a different modem
I have just bought a Linksys ADSL 2 Modem and I want to connect to my Plus Net account using this device. Any ideas? My computer does not detect it as a modem but as a Network Adapter.
Moderators note by John (johnesex) Not really a customer feedback item so moved to a more appropriate part of the forums.
1 REPLY
I can really only suggest reading the user manual for it. They're usually fairly helpful in these circumstances. The Connection Details page here details exactly what you need to put for all the details (username/password/etc).
You should note that Windows XP usually treats xDSL connections as Dial-Up connections unless you have a router and as such you still need to dial a phone number. It doesn't matter what you put as the phone number, the modem will ignore it. IIRC the default for my old USB modem was something like 38,0 but, again, the instruction manual should tell you more.
