User document folder structure on XP Home
Not a 'computer/hardware' question, but I'll give it a go!
First time user of XP Home.
Created user - 'Trevor' (I only have one user on my pc).
Computer created file 'Trevor's Documents', (at least I dont remember creating it)
Can't save a document when using 'save as' into 'Trevor's Documents' (the folder doesn't appear in the window) - am guided into CCheesyocuments and Settings/Trevor/My Documents - but if I look in 'Trevor's Documents' via windows explorer after saving in CCheesyocuments and Settings/Trevor/My Documents, exactly the same files are in both places and if you delete one they both disappear.
If I create a file in 'Trevor's Documents' also appears in CCheesyocuments and Settings/Trevor/My Documents.
Is this normal. Is everyone's set-up like this.
What is the logic behind this.
Should these folders be used for different things.
Why can't I save a new document in 'Trevor's Documents'.
If I've done something wrong in the initial set-up, how do I put it right.
Does it matter.
Thanks,
Trevor
1 REPLY
They are one and the same folder!
Trevor's Documents = C:\Documents and Settings\Trevor\My Documents
And yes, it's perfectly normal!
