Uninstaller software
dscott
As I'm about to have a spring clean of my pc, I'd be grateful if anyone could recommend the best software which will help get rid a 3 years worth of accumulated files, demos etc. Any advice given will be gratefully received.
Best wishes,
David
1 REPLY
While you can get software that will help with that, I always recommend to those that are able that, after a period of time such as yours, you backup important data then totally wipe your hard drive - you can make a fresh start, and you might be amazed by the performance boost you get!
Thomas
