USB Ports
USB Ports
wheni start my system it does not find any of my usb devices i have to unplug them and then plug them back in im running windows xp sp2
when i do this they work
help :x
[Moderator's note by Chris (Eurotrain4): Title changed from all capitals as this is harder to read and considered rude]
USB Ports
did this happen AFTER installing SP2 or did you install XP with SP2 intergrated and it just didnt find them?
anyway
drop to your device manager (its on the properties of "my computer") and see if you can see them, i would assume a hardware conflic or corrupt USB chip set drivers.
buz
USB Ports
Boot into safe mode and remove all USB devices from device manager. Then reboot normally and get windows to find the devices again.
Also look for updated chipset / USB drivers for your mobo.
USB Ports
i found that it was my sound card just to old have got a new one and all runs great now
thanks all
