USB Port not working
I have built a PC using an Asrock MB. There are 4 USB ports on the back and two on the front. All was working well, but, suddenly, 2 of the rear ports have stopped working. I have tried reinstalling the drivers, but to no avail!
Has anyone got any ideas?
Many thanks.
Are the ones on the rear on the motherboard it self Huh
Yes, they are. There are 6 on the rear, but when you have 2 at the front, 2 of the rear ones are disabled. The two that aren't working are in addition to these 2.
Does that make sense?
I don't know what's happened, buy, since I've installed SP2 they all seem to be working. Perhaps there was an update which fixed my problem!
Yeah thats werid that. I have four at the rear and 2 on the front and all work. Very werid
i have the same MB as you and i had trouble with my usb not liking my old sound card i changed it and fitted a usb sound card and all work well now
funny a Tongue
