Two computers shearing Quickbooks 2002 multiuser
Tiger50
What would be the best way foward to allow two computers to multiuser quickbooks 2002 in two offices 10 miles apart.
Both running XP pro
Both on broadband
The main one is in a net work the other is stand alone
Someone has suggested vpn......
Thanks for any suggestion
1 REPLY
Denzil
Don't know anything about Quickbooks but VPN (Virtual Private Network) should work. It effectively makes the remote computer part of the network. The drive with the data will need to be set to shared, I would assume, then set up QB accordingly. Type VPN on XP help and you should find some instructions.
Denzil
